kremlin 10;1 air assist -- 0 --
1/17
I need answers!!!!had this thing at our cab shop for a coupla mths.just need to know if im supposed to be get my paint up into that reservoir.seems to me if paint can get up there,the lubricant that you put in there could be getting in my cv,and causing slight overspray looking scaling.just nobody I know intelligent enough for this new gun that I can ask questions about ,id appreciate someone familiar with these kremlins .thanks
1/17 #3: kremlin 10;1 air assist ...
Maybe can you rewrite the question?
Is this a EOS Kremlin 10-1 or an older version?
Are you talking lube reservoir on pump and or issues with the gun (Xcite)
If paint is passing up the pump shaft into the lube reservoir this is not normal and you need to replace the seal cartridge on the pump shaft
1/18 #4: kremlin 10;1 air assist ...
Thx bhand,that was my main question,yes its new,the xcite gun seems great,im just new with these air assisted thingamajigs.its just hard to troubleshoot without support.the paint company we got it from is not anyone i even trust to answer the simplest questions.our bad.yeah,paint goin up in that lube resevoir.just seems to me that if paint can go up in there,that lube could be gettin in my topcoat
1/18 #5: kremlin 10;1 air assist ...
Hello William have you always maintain lube level in the reservoir using the the Kremlin lube? Dry reservoir means $ and seal replacement
Regardless try contacting Kremlin to see if they can assist you or if they will do warranty goodwill work .
If your handy it is fairly easy to replace, in fact Kremlin has a You Tube video on the pump rebuild. Upper seal kit is around $140
1/18 #6: kremlin 10;1 air assist ...
if it has been run dry and not full of lube all the time you will be lucky to get by with just an upper seal on the fluid section on a 10:1 kremlin.... The culprit is usually negligence to keep the cup full, clean and junk free....If it runs dry and there crud and sediment in the cup it will score and scratch the piston rod... new seal will fix it for a month or so then the scratch on the rod will be tearing the new seal and start leaking again..... most likely time for a new piston rod and lower rebuilt packing kit.... It's very easy to tear down and replace the seals.... you just need a nice heavy duty bench vise with soft clamping jaws to get the lower half unscrewed... and at least a big pipe clamp or even better a very large open end wrench that fits the groove so you don't mar up the cylinder outside while taking it apart.... I've done about 50+ of those kit rebuilds on 10:14's
1/18 #7: kremlin 10;1 air assist ...
Good points Shane, if he is into top and lower seal kits and pump shaft it could get expensive. Where do you get your kits from?
1/18 #8: kremlin 10;1 air assist ...
the paint company that sold it to us had to replace piston seal about a week after we bought it.(supposedly)because paint was going up into the reservoir.yeah,kept fluid in it.but that didn't stop the paint from rising even after the (new)seal.just bad service I think.i really really appreciate yalls input,thanks so much
1/18 #9: kremlin 10;1 air assist ...
been getting a slight blistering overspray looking thing in my cv.its just very random,and im just thinkin its contamination from that lubricant.just very hard to nail down
1/18 #10: kremlin 10;1 air assist ...
The lubricating oil is designed not to interfere with designed clears/paints. Unless it is leaking into the piston at an alarming rate the miniscule amount that make leak by shouldn't affect your CV.
1/19 #11: kremlin 10;1 air assist ...
I service kremlins..
I have never had an issue with lub leakin past piston assembly and into the cylinder..
What can happen, is over fill or spliiage in the lub resivor can contaminate the Material inlet and possibly the the fluid pick up tube..
Or a loose drain plug can leak fluid in same manner..
1/19 #12: kremlin 10;1 air assist ...
if it was replaced recently then you definitely have a piston rod that is scored... tear it down and inspect it... clean the rod in solvent and check for scratches... if you can catch it with a nail then a new piston is in order... Currently we buy our rebuild kits & parts through Sherwin Williams product finishes division and secondly airpower
1/24 #13: kremlin 10;1 air assist ...
shane where are you located? and do you rebuild kremlins for finishing shops, want to have ours gone over and have seals replaced thanks
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
