green dye
1/23/17
Tony
I have a job coming up that I am doing samples on and both my finish suppliers have let me down on green dye. I have always kept a gallon for just such a situation (killing some red) but used my last a few weeks ago. I currently use ChemCraft and my supplier says they don't make it anymore. Another supplier carried Mohawk, but has since stopped carrying finishes at all. I am in east TN. Just wondering if you all had run into this situation (not made anymore?) and if so, what alternatives would you suggest. Thanks
1/23/17       #2: green dye ...
ThomasFR2
Mohawk sells direct to user. Get their catalog. Good luck
1/23/17       #3: green dye ...
Hen Bob Member
Richelieu?
1/23/17       #4: green dye ...
What color can't they get, probably blue? Seems to me you could get some stain base and add blue and yellow universal colorants.
1/23/17       #5: green dye ...
chris
check wd lockwood stains
http://wdlockwood.com
1/24/17       #6: green dye ...
kevin
im with Rich.... blue + yellow = green
1/24/17       #7: green dye ...
Mark V.
This is what I use....
(scroll all the way down to the bottom :-)
Mark
TransTint
1/24/17       #8: green dye ...
Tony
Thanks for the responses. I just didn't want to have to purchase a gallon of yellow and a gallon of blue-the gallon of green I had, I have been using for 3 years (just a touch here and there to adjust a color). Mark-that's kinda what I was thinking, just didn't know for sure if it would be compatible with my stain base (ChemCraft Vivid stain base).
1/24/17       #9: green dye ...
Pat
Call or email Homestead and ask. Jeff Jewitt is the owner. He's very knowledgeable and can probably tell you if the TransTint will work with your products.
1/24/17       #10: green dye ...
I commented about the blue and yellow because I thought every paint store in America has blue and yellow universal colorant. Just take a gallon of your tint base and a color swatch you want to match.
4/24/17       #11: green dye ...
Robert Member
Ilva dye concentrates offer a couple of different greens.
http://ilvacoatings.com
