Prefinish Panel
1/26/17
Howard Gorman Member
What i have been doing so far is sanding the edge of the frame so the finish can get under it and prevent a line from shrinkage. If the panel is prefinished, do you cover it and then finish the frame?
if you don't do that, how do you prevent too much of a build for the panel that is not consistent with the frame?
1/26/17       #2: Prefinish Panel ...
Flat panel or raised panel? My procedure is to apply any stain or dye on the entire panel, then a light coat of sealer. Then assemble the door, color the frame, then go to the regular clear coat schedule on the entire door. That light clear coat on the panel prevents the color applied to the frame from changing the intensity on the panel and doesn't show as having a heavier clear coat.
1/27/17       #3: Prefinish Panel ...
Just wipe some stain or sealer on the panel edges. The movement is minor and as long as there isn't a massive change in color(unfinished wood) no one will notice. The finish will soak in so there is no build up. If you break the edges too much, the top coat will collect there. It may leave a little ridge line when the panel shrinks.
