White wash with sherwin williams cv system
2/11/17
antonio
Website: http://positivewoodworks.com
about to get into a pretty good sized job involving white washing (or white pickling) of 2' x 8' maple panels. We haven't done this since we switched to CV years ago. We had a pretty good system before we knew about CV where we used a WB clear finish over a ragged on/off white WB paint. That was ok in its time before we knew about the durability of CV so we want to try this with white pigmented CV and water white clear CV preferably with sherwin williams products. My question is, can white pigmented cv be thinned enough to be a good white wash sprayed on? Or better yet, what methods are you guys using with CV to get a good white wash?
2/12/17       #2: White wash with sherwin williams cv ...
Sean Jackson Member
I've achieved this look a few times, here's how i go about it: under a clear CV finish i use white pigment (water) stain, maybe diluted 50/50, I think id be sealing off the maple with a thin 50/50 thinned sealer (thinned varnish) as maple might be uneven in absorbing any colour and finishing off in clear CV.
White coloured (milky) CV used to get a washed out/white look hasn't worked well for me in the past. Going with a thin white colour led me into warm and pink white hues as the base colour becomes more of a factor obviously. Plus 'coloured finish' is never going to look as good as a clear finish for wear and tear I think.
2/12/17       #3: White wash with sherwin williams cv ...
antonio
thanks sean, you used a wb stain under clear cv with no adhesion issues? or was there a cv clear sealer applied over the stain first as a barrier coat?
2/12/17       #4: White wash with sherwin williams cv ...
Sean Jackson Member
a water based stain that has dried is fine under a CV finish, use them all the time as well as light fast, it's generally oil based stains that are no go with CV (or AC lacquer here in UK). The sealer I talked about was just to ensure the maple is lightly sealed off and didn't go blotchy.
2/13/17       #5: White wash with sherwin williams cv ...
Shane
if you use all Sherwin based system I would do the following especially since you have a decent size run. Doing it this way would be very fast and very consistent:
Sherwood SB Stain colorant D59W85 White 200 grams with Wiping Stain concentrate clear base S64T28 200 grams. Naptha 500-1200 grams.
take this basic formula and play with the naptha ratio to use it as a spray stain... Put it in a pressure pot with a decent gun and spray several passes spraying just barely wet and overlapping strokes with gun pattern at pencil point just to where it starts to turn into a fan.. build the color to your desired opacity...... samples samples samples... come up with your formula and the approximate pass count for the panel and this will make very quick work of the whole run..
Use T67F7 Vinyl Sealer catalyzed with V66V26 at the correct rate and reduce with acetone 15% to keep the film build down, makes a quick flash to sand and topcoat with V84F90037 (What I prefer) or their kemvar water white stuff... One semi wet pass coat of topcoat... light flash and recoat within ten minutes and they will be perfect...
2/13/17       #6: White wash with sherwin williams cv ...
antonio
thank you shane, in your response you answered one of my main questions -- whether i could use the white sw sb stain. Thanks will give that a shot!
2/15/17       #7: White wash with sherwin williams cv ...
Shane
Follow up and post some results and photos!
