What to do with waste water...
2/15/17
kevin
We are a large shop looking into converting solely to waterbased coatings. We currently use a couple hundred gallons of acetone a month and have a substantial waste stream as a by product. We do have a solvent recycler on site which cuts our waste back but im interested in what is being used on the waterbased side for this?
We do a lot of changeover of different materials throught the day which requires flushing and gun washes constantly. So, what are some ways to deal with the waste water that would accumulate? (Aside from putting it in a drum and paying someone to haul it away)
Im sure there has to be some sort of evaporative tank that removes the water and leaves the solids.
Or maybe a less technical way thats working for some of you?
2/18/17       #3: What to do with waste water... ...
Bob Niemeyer
Website: http://niemeyerrestoration.com
Kevin, Two thinks you need to do.
1. you can buy a coagulant to add to the waste water. This will coagulate the coating and make it fall out of solution and settle to the bottom of the drum.
At this point you can have the left over water tested by your local wastewater treatment utility to see if you can place it down the drain. As long as it does not kill the bacteria in the sewage digester and meets other requirments, they may give you the ok to let it go down the drain.
2. The coagulated finish can be air dried and delt with as dried paint.
With a little work on your end you can save lots of money!!
2/19/17       #4: What to do with waste water... ...
Bart
Pretty much everything Bob said.
As a side note. In an earlier phase of my life I built surfboards and we used crazy amounts of acetone. The recyclers came along and that helped. Fast forward a few decades to today. A good friend of mine still owns/operates a large surfboard factory here in SoCal. They just burned down due to a malfunctioning/sparking acetone recycler! Luckily no one died but it was close. So not only will you save money/health with a little work (less than dealing with acetone for sure) but you could save someones life including your own.
good luck
Surfboard Factory Fire
2/20/17       #5: What to do with waste water... ...
kevin
Thanks for the advice both of you. What is this coagulate called? Do you have a supplier you could refer by any chance?
2/20/17       #6: What to do with waste water... ...
Bob Niemeyer  Member
Kevin, Start with your coatings supplier for the product as what is used could change based on resin system in the coating. If you get no response from them let me know and I can get you to someone that can get you the product.
2/23/17       #7: What to do with waste water... ...
Alessio Member
Hello Kevin, I suggest you to use a proper water recycler, we have one that is called concentratore, they are cheaper than a typical solvent recycler but the functioning is more or less the same.
