Rosewood tabletop trim repair advice.
2/23/17
Matthew Member
I am a furniture refinisher, but currently am looking at a project that requires a bit more fabrication.
I have a large, vintage oval Rosewood tabletop that I am going to refinish. The substrate is plywood with Rosewood veneer. The main area that needs to be addressed is the trim... about half of it is missing. It's a pretty simple half round, but solid Rosewood and I imagine it was shaped after glue up.
My question is: how would you approach this? My current plan it to remove the remaining trip, strip and prepare the table surface for finish, and then fabricate new trim. I'm hung up on how to proceed from there.
The trim exists in lengths of about 3 feet. I don't really need to reapply it to exactly the same dimensions, but it would be nice. I was thinking Walnut... but is there a better species for this?
I haven't done any steam bending before... is this beyond my scope? As far as I understand, I will build a steam box and steam it, then fit it to the table top and clamp it in place with a jig that matches the table shape. From there, am I good to glue up, or? I have read here about potentially not getting a good glue joint after steaming.
I have a shaper and bit that will get me 75% to the profile of the trim, and then I can finish shaping after glue up... is that my best choice?
Thanks all for any advice.
View higher quality, full size image (4288 X 2848)
2/23/17       #2: Rosewood tabletop trim repair advic ...
Matthew Member
And here are pictures that show the damage, the missing trim.
2/23/17       #3: Rosewood tabletop trim repair advic ...
Shane
that trim is thin enough that it would probably take the shape without a steam box.. although a good steam bath would definitely limber it up.... I bet you could make a pvc pipe steam box pretty cheap. I'm sure walnut would be a decent alternative... you could even bleach the walnut to get some of the color out to make sure you have room to match the rosewood.... Also a polyurethane glue like gorilla glue would shine in that application since the gorilla glue is a moisture cure system.... you will just have a lot of cleanup to do with the squeeze out expanding. seems pretty straight forward... just make some square rips close to that size in walnut and see how well it bends at that thickness before you set up a shaper for profiling...
2/23/17       #4: Rosewood tabletop trim repair advic ...
denny jahnz
I would glue and clamp the new edge on and then use a router to profile the edge after its dry. If you can't get the wood to bend at the thickness it needs to be, then make two strips half that thick and clamp them on. Once dry you won't notice the difference.
