bubbles showing up over black stain
2/23/17
Sam McRae
Hello All,
I am trying to successfully coat oak veneer (core is plywood). The customer requires an ebony stain on this, which is a pigmented (ebony) vinyl sealer. Once applied and dry after an hour, I seal with a pre-cat lacquer sealer, dry time is 15 minutes for this. Then top coat with flat sheen lacquer. So the oak pours are well sealed and being it is a veneer, why am I having bubbles? My next thought was the top coat but this is mixed down 50/50 with lacquer thinner shot with an automotive cup gun and HVLP gun itself. So that it all I can think of. What would cause bubbling after all that I described? Cup gun settings are low (just enough to atomize). Any other thoughts on this? Bubbles are trapped air but why would I have them here? Thank you All. Sam
2/23/17       #2: bubbles showing up over black stain ...
Traditional lacquer on top of precat? Have you done that on other applications? Seems suspicious to me.
2/23/17       #3: bubbles showing up over black stain ...
denny jahnz
Thin the first coat, reduce the air pressure, back off the distance from the tip to the piece.
2/23/17       #4: bubbles showing up over black stain ...
Arthur grudko
Oak is a grainy wood, and can induce pinholes in the initial coats. If the sealer coats dry too fast, they can bring up the air in the grain dots and trap the air and become bubbles. Then the bubbles can become frozen.
Try a little retarder in the sealer coats, and spray them on thin.
2/24/17       #5: bubbles showing up over black stain ...
Sam
I appreciate the tips. Yes a lot of our furniture we've made in the past we used cab acrylic lacquer over precat lacquer sealer. Seemed to work fine until I needed to apply an ebony stain. Will certainly try the other ideas as well. One thing I learned today in using the vinyl/stain combo, there is no need for a precat sealer. Sounds like it wouldn't hurt me to try that as well.
Thank you All.
Sam
