Finishing a maple island top - help please
3/12/17
henry Member
Planing using a water based lacquer for the finish - has anyone used J.E. Moser's Premium Spray Lacquer? Do I need to put a sealer coat (dewaxed shellac) on prior to applying the lacquer? Any help will be appreciated.
3/13/17       #2: Finishing a maple island top - help ...
Dan cook Member
Don't know about water base,but M. L. Campbells polarian is a great finish for an island top. Use the same material from start to finish. Tough as nails when finished. Product must be sprayed.
3/13/17       #3: Finishing a maple island top - help ...
Leo G
I second the Polarion. If you use the slow thinner you can actually brush it on, not that I'm recommending he do that.
3/13/17       #4: Finishing a maple island top - help ...
RobertJ
If you are truly interested in only using a Waterborne product, look at the wood flooring industry coating product line up.
Lots to choose from: Bona, Glitsa, Duraseal, etc.
3/13/17       #5: Finishing a maple island top - help ...
henry cornelius Member
Thank you for all of your responses -
3/15/17       #6: Finishing a maple island top - help ...
denny jahnz
ICA has a web that should fit your needs You will pay for it but the coat is relative to quality.
