Color changer valve
3/31/17
Abrasive
Anyone can tell me what is the color changer valve used on this video?
https://www.youtube.com/watch?v=g1yqZ5zyqhc
3/31/17       #2: Color changer valve ...
herb johnson
its just a standard 4 way ball valve, he is only using three ports, you can do the same thing-cheaper typically- buy ganging together 3 balls valves and one for solvent
3/31/17       #3: Color changer valve ...
Abrasive
Thanks!
If i only needed to change between Sanding sealer and top coat what would be the best/cleaner method?
4/3/17       #4: Color changer valve ...
herb johnson
i would use what ever cleaning solvent you use currently, will work just fine
4/4/17       #5: Color changer valve ...
Shane
just make sure your plumbing is stainless if your using waterbased or any acid catalyzed precat or post cat material or you will have problems
