Steps for Milk paint then Glaze then poly
4/26/17
Tom Member
I am doing a test cabinet before I start a project. I am doing GF antique white milk paint with Grey Glaze then Enduro Poly. I am thinking put 2 coats of Vinyl sealer on the mdf first then Milk paint. Since it is white I think that I will need to seal it next. This is where I am not sure do I use a coat of the poly or a coat of vinyl sealer? after this it will be glaze then Poly.
Thanks for your comments.
4/27/17       #2: Steps for Milk paint then Glaze the ...
Bart
I wouldn't put vinyl sealer over GF milk paint. It's WB and you could end up with a serious mess on your hands. Just use their sealer. I would also put a barrier coat of their sealer on top of the vinyl sealer. Mist a light coat. Scuff. Then a fuller coat. You really need to do some samples before ruining your woodwork. I've used Bin shellac based primer on mdf under GF white poly numerous times to help to stop the grain raise. If that is your issue.
