Sanded area on pre finished post
4/28/17
Russ Member
Hello All
I have these American Cherry newel posts that were pre finished with lacquer prior to installation. After the plugs were put in the area was sanded and since then the painter has come back to re finish and we now have this blotchiness. I had told the owner that pre finishing was not recommended because the final finish will not match. Does anyone have any suggestions on how to fix at this point. Im guessing the obvious would be to sand out the entire side of the posts and finish the entire side rather than a small area. But Im not the expert.
View higher quality, full size image (454 X 501)
4/28/17       #2: Sanded area on pre finished post ...
Bob Niemeyer  Member
Best way is what you are thinking , just rework the complete side of the post.
I have done a ton of these in new homes where the carpenter gets a little carried away with the sandpaper and then the painter thinks it is a easy fix.
This is why "Painters" are not finishers and also a good finisher can do excellent touch up.
4/28/17       #3: Sanded area on pre finished post ...
I'd suspect the original was sanded to 220, the patch to 150. Giving two colors.
4/29/17       #4: Sanded area on pre finished post ...
D Brown
I would guess the stain is residue from the filler or putty used .
4/29/17       #5: Sanded area on pre finished post ...
nicko
i agree with Dbrown it looks like putty residue or glue smear from gluing a plug in.It needs to be sanded more thoroughly
nicko
4/29/17       #6: Sanded area on pre finished post ...
Glue smears always show up clear or white. More likely a wipe down with a wet rag and swollen grain from the water. That swells the pores and absorbs finish differently.
4/30/17       #7: Sanded area on pre finished post ...
The woodworker in me says that the plug was put in poorly. The installer then covered his tracks with sander dust/glue filler. That is why the outside of the plug is super dark. You are seeing end grain dust wetted out with glue. It always shows up as dark while glue by itself shows up whitish.
