bronze metallic look finish
5/2/17
Dan Cook
I have been asked by a commercial client to do some wall dividers that will have a bronze look pattern in the center field of the divider. The pattern is about impossible to do with real brass etc. so I was wondering about some metallic type finish that would be a good substitute. Any suggestions? thanks
5/2/17       #2: bronze metallic look finish ...
CRIS
Art nouveau or plate all. Plate all is more durable, I believe 30 year outdoor warranty on plate all.
5/2/17       #3: bronze metallic look finish ...
Bart
If you're set on finishing it modermasters has lots of metal effect products or you could look at real metal laminates or faux metal laminates.
http://www.modernmasters.com/landing/homeowners/brands/me
5/2/17       #4: bronze metallic look finish ...
Matt
Modern Masters is good, I've used several of their colors to good effect.
If you require the durability of conversion varnish, add something like Pearl-Ex bronze pigments (avail. on Amazon, not cheap, but it works).
We've done a good bit of Pearl-Ex in clear conversion varnish. My test project was a metalflake clearcoat on my son's wooden monster truck, looks awesome and has held up to his abuse for 6 years now (mixed into MLC Krystal). Since then we've used it to spray cabinets, etc.
Pick a base color that is similar to bronze, the base color gives a MASSIVE amount to the final look.
Play with your powder amounts, and spray carefully. I would not spray it out of an AAA pump, I don't know what the pigment pieces would do to the pump or the tiny orifice in the tips.
5/3/17       #5: bronze metallic look finish ...
RobertJ
Contact 'Seagrave Coatings' in New Jersey, they may have something in their line of coatings.
5/3/17       #6: bronze metallic look finish ...
chris
check out luminore coatings.
5/4/17       #7: bronze metallic look finish ...
Gary Member
luminore is a great product, I have done a lot of work with that coating, I had take an online coarse and test before I was able to purchace it, and spray it.
