RE: Finishing a Hardwood
5/6/17
Tommy
If I am going to put a finish or sealer on one side of a 12-inch wide x 7 ft. long x 1/4 inch thick piece of hardwood (red oak, white oak, or poplar), do I need to put a sealer coating on the back side of the wood to prevent it from cupping?
In other words, does the side that is not being used have to have a sealer or finish on it to prevent it from cupping or can it be left plain?
5/6/17       #2: RE: Finishing a Hardwood ...
It needs the same thickness of finish on the back as the front. That described piece of wood can easily cup just sitting on the bench if there is a wide enough humidity change.
