green walnut mantle
5/1/17
dw
when making a walnut mantle from wood that is wet yet, what kind of finish would you use?
it is holding about 35% moisture. i know that it will crack and split but it is rustic and being placed on rock.
5/1/17       #2: green walnut mantle ...
Jr Lee  Member
Website: http://www.leecabinets.com
Dw, a word of caution about a mantel that is not dried properly. I finish custom mantels for a local company. They supplied a mantel and I finished it per normal process. I didn't verify the moisture content. Long story short, after the mantel was in place and the fireplace burning for a while, the finished started bubbling. The company of course thought I had done something wrong. After finding the moisture content was around 14% I advised that we strip the mantel and have it KD'd properly. I refinished it and no more bubbling. Don't finish the mantel if it is not KD'd properly.
Jr
5/1/17       #3: green walnut mantle ...
Leo G
Only thing that would work would be a penetrating oil.
5/8/17       #4: green walnut mantle ...
The Cajun Craftsman Member
You could try CPES (Clear Penetrating Epoxy Sealer). I've used it on high moisture slabs before and it sealed the wood sufficient for top coating. But these are tables kept at room temperature and not above a fireplace.
5/9/17       #5: green walnut mantle ...
Matt
I would not put a film finish over that.
If it's rustic, you don't want a shiny, smooth film finish anyway.
As said above, an oil finish is going to be more applicable. It won't bubble, and will look quite rustic. Linseed oil is OK but true (100%) Tung oil is better in my opinion and more durable. Should be just fine on green wood, especially if you can give the completed part some air drying time after it's been prepped, maybe a day or two, where the surface is dry enough to accept the oil.
