white pigmented conversion varnish VS. urethane 2k
5/18/17
antonio ageeb
We have been using sherwin williams white pigmented CV kemvar plus for a few years now and mostly with excellent results spraying hundreds of white shaker doors. We are thinking of upgrading (which i think is an upgrade) to poly 2k. Mainly because of mil thickness issues we had with CV cracking before. As of now we are not sure if sherwin makes a white poly 2k or not will have to look into that some more. My questions are, how does poly 2k compare as far as staying white like CV and ease of spraying?
5/18/17       #2: white pigmented conversion varnish ...
chris
check out Sayerlack.It is a Sw brand.
i use 2 K urethane in clear and have never had problems with it.
only downsides are a shorter potlife and cost.
5/18/17       #3: white pigmented conversion varnish ...
antonio ageeb
thanks chris, does it come in a white pigmented version? if so have you ever used it?
5/18/17       #4: white pigmented conversion varnish ...
ML Campbell has a 2K called Polarion.
It to has a short pot life but it's cost is pretty close to a more expensive CV.
5/21/17       #5: white pigmented conversion varnish ...
nick
I use a lot of SW F3 formaldehyde free CV mostly the clear but also the pigmented (both outstanding products BTW) but lately I've been using the clear MLC Polarian for items that could use a tougher yet more flexible finish (restaurant tables/bars and walnut sinks I've been been finishing for a local wood turner). Super easy to spray and the pieces come out flawless but like others have said it's a little more expensive (about double what I pay for the F3), has a short 4 hour pot life,it's not a self-seal system (so you must buy/use the sealer and what I have yet to get use to...at least a 1 hour sand/re-coat time. Both the sinks and the table tops I finish with the Polarion are all sides so sealer and 3 finish coats takes at least 8 hours to complete as opposed to 2.5-3 hours with F-3 CV.
Since this is the only 2k poly( besides automotive stuff) I've used
5/21/17       #6: white pigmented conversion varnish ...
nick
I cut that last sentence short.what I meant to say was; since this is the only 2k poly I've used other than automotive stuff I cannot speak to the attributes of other 2k wood finihing products.
5/21/17       #7: white pigmented conversion varnish ...
Leo G
You can do a wet on tack coat for the Polarion. Spray the sealer, let it dry 45-60 minutes and sand smooth. Then do 2 or 3 coats wet on tack, no sanding in between.
Obviously only one side can be done unless you are using a nail board.
5/21/17       #8: white pigmented conversion varnish ...
nick
I did use the wet on wet finish coats on couple of the sinks and it did save on the total time it took to finish a piece...but for me the wet on wet method took quite a bit longer then a single coat to dry/cure well enough to turnover without causing damage.
