kremlin replacement oring part #
5/27/17
aj
anyone know the part number to the inner ring(smaller) on the kremlin excite spray gun? thx
5/27/17       #2: kremlin replacement oring part # ...
Bob
If no one has it, I will go down to my shop tomorrow and find my Kremlin book. I have the same gun.
5/28/17       #3: kremlin replacement oring part # ...
kevin
theres no ring there... that fits inside the spray tip and the flat part butts against the seal inside the tip.. the only o-rings on that are the one on the outside of the nozzle and the one inside the spray tip
5/28/17       #4: kremlin replacement oring part # ...
kevin
and from the looks of your dirty nozzle, you have flattened the seal inside the tip. these need to be changed pretty often.
5/28/17       #5: kremlin replacement oring part # ...
Leo G
Wow. Time to clean that thing up. I use a ultrasonic cleaner with water based stripper. Just take the Teflon O rings off and throw it in there for 1/2 hour or so. It'll come out looking like new after you brush it down. Also go to the auto store and get a set of Jet orifice cleaners. You can clean out the outer ring of holes that supply air to the cap.
I don't have the Excite gun so I can't help you there.
5/28/17       #6: kremlin replacement oring part # ...
Brewster201 Member
Hello here is a chart with all part # for the Xcite gun
View higher quality, full size image (2199 X 1410)
5/28/17       #7: kremlin replacement oring part # ...
Leo G
Here's something
Xcite ™
5/28/17       #8: kremlin replacement oring part # ...
aj
thanks guys, this was after a heavy day of spraying. I also use a crest heated ultra sonic cleaner with acustrip WB cleaner. I did however learn something new.... I had no idea that a oring did not go as shown in my pic. i also change out the tip o rings but allways had one around the inner nozzle as well. In fact both of my kremlin had it. they must of worked there way out of some tips onto the nozzle because i have never intensionally installed them there. Thanks for the help.
5/28/17       #9: kremlin replacement oring part # ...
chris
an o ring does go there.
part # 129.729.912
you will notice a groove where the o ring seats into.
older ones didn't have it but i have same on mine.
5/28/17       #10: kremlin replacement oring part # ...
aj
thanks chris for the confirmation. I was begining to think i was starting to go a bit crazy since both of my sprayers have them!
5/29/17       #11: kremlin replacement oring part # ...
kevin
my kremlins dont have an oring there ..
ive had em for a while tho!
5/30/17       #12: kremlin replacement oring part # ...
Shane
Gentlemen,
the Kremlin excite gun does have an oring there....When it's fresh its a pain...lol everytime you take the air cap off your tip is still sitting on the nozzle holding tight.. the older MVX & MX guns did not have the oring on the nozzle.
