Blotchy results when spraying toner
5/28/17
Bob Walberg Member
I have been experimenting with toning using a water-based aliline dye in a wb polyurethane. I mixed powdered dye in a litre of hot distilled water. I made a 10% toning solution using Deft wb polyurethane. I sprayed a sealing coat od Zinsser shellac, sanded w/ 220 and sprayed a coat of toner. Excellent results. However, my second coat (2 days later) resulted in an uneven distribution of the colouring. I thought that I had stirred the toner thoroughly. The toner is over maple ply, ash, and spruce. Same results. The problem isn't the wood (I know how maple can give blotchy results). I'm thinking either using only fresh toner (the toner for the second coat was 2 days old) or moisture in the air. I do have a water seperator, but may have beef up this aspect. Any thoughts?
5/28/17       #2: Blotchy results when spraying toner ...
Bob Walberg Member
I think that I may have answered my own question. Operating on the assumption that the toner wasn't mixed sufficiently, I made sure that I stirred the toner before and frequently during spraying (the other side of the project). Happy to say that I got nice, even results. This was a project for the learning. When it really counts, I will be better prepared.
5/30/17       #3: Blotchy results when spraying toner ...
John Member
I've never had color separation in the toners I've used; didn't know it was even possible because the dye is in solution. When I make toners in my WB topcoats I add the dye directly to the finish as I don't want to dilute the finish. If you added more than 10% of your dye solution to your WB finish I would be suspect that that might be the root of your problem.
Generally, I make toners by adding Transtint dye to Sealcoat shellac, and only use it in my WB topcoat when I need to shift the final color.
John
5/30/17       #4: Blotchy results when spraying toner ...
Bob Walberg Member
Thanks for your input John. Unfortunately, Transtint is not available in Canada, or at least I have not been able to find a source. General Finishes has a liquid wb dye that they describe mixing with their polyurethane. GF are available at Lee Valley, which is available here. That's kinda where I got the idea.
5/31/17       #5: Blotchy results when spraying toner ...
Denny J
I generally don't add the toner to the top coat. GF has a base to use for this. If added to a clear, the blotchiness is probably from not having a uniform wet coat so the thin parts dry and you get pooling in the heavier areas. Without pictures it's hard to tell.
5/31/17       #6: Blotchy results when spraying toner ...
JT Member
Bob,
You can get (what I believe is the same product as Transtint) from Wood Essence in Saskatoon. They call it ColourFX. I've used both with the same results.
JT
5/31/17       #7: Blotchy results when spraying toner ...
Bart
Bob, toning gets harder the further along in the process you go. Your first toning attempt was in partially sealed wood. The 2nd was pretty much sealed so the finish/toner is sitting there. Depending on how well your gun atomizes you could easily get that "separation" look. Of course mixing is important but most hvlp guns will give you a "pulse" pattern. I typically pump up the air and reduce volume if I have to tone. Also you'll want to use a metalized dye to protect against fading.
good luck
