Favorite strainer for 3/8" pickup tube on AAA?
5/31/17
Matt
Sorta a mundane question here but what is your preferred pump intake strainer? We run 3 AAA pumps, and I'm getting tired of the plastic housing on them getting wore out after a few days. They used to last for weeks, but recently the plastic seems to expand when contacting the solvents in conversion varnish. At $8 each, it's getting silly.
Just looking for an alternative, either cheaper, or something that will last for weeks like it should.
Slip fit onto 3/8" steel tubing.
5/31/17       #2: Favorite strainer for 3/8" pic ...
kevin
we use the plastic ones.. and havent changed them in well over a year.
we use conversion varnish and go thru well over 100 gallons a week.
what i did to make them last longer is i take a plastic cap from a jar and place it in the bottom (this stops the pickup hose from puncturing it) and then we just buy the disposable spray filter bags that have a drawstring on top. we tie that over the filter and then change them every month or so.
5/31/17       #3: Favorite strainer for 3/8" pic ...
kevin
the filter socks are like 12 for $20
View larger image
6/1/17       #4: Favorite strainer for 3/8" pic ...
Matt
I see, and I have a few of those filter socks laying around we could do that with, thanks.
6/1/17       #5: Favorite strainer for 3/8" pic ...
kevin
one more thing we had to do that i forgot to mention.. i think from what your describing this may be how we solved the issue ur having...
the plastic ones we have are almost the size of a soda can. the sides and bottom are mesh and the top is plastic that snaps onto the body. they do expand a bit from the solvents so that likes to fall apart. What we did was made 2 small holes and just used some wire to secure it. just run it thru the hole in the top, then out thru the mesh, back up and twist the wire together. Snip off the excess and ur good.
