epoxy sealer under 2k poly?
6/8/17
Nick
more specifically; Does anyone know if MLC Polarion will go on top of Smith's Clear Penetrating Epoxy Sealer without issue or will a barrier coat between them be necessary? Thank you.
6/8/17       #2: epoxy sealer under 2k poly? ...
Leo G
I can't help you with that brand of epoxy. But I just did a slab that I filled holes with the West System epoxy, I used the 207 hardener which is designed to have finish applied to it.
Since my slab was Bubinga I had to use Isolante which is a isolation/oily sealer. Seems to stick to the epoxy well.
6/9/17       #3: epoxy sealer under 2k poly? ...
I built a table top out of yellow pine LVL by ripping into strips two inches wide and re ripping the original faces to clean up and remove wax. I then edge glued them, kind of looks like Bamboo. After testing with a ball point pen I thought it was to soft for a dining room table. I applied two coats of Smiths this helped with the hardness issue, and did an great job of sealing the surface. I then sanded it to hand sanded it to 220 and applied a coat of Bona Traffic to it. The next day I was scuffing the Bona for a second coat and noticed a spot that rubbed threw, I started picking at it with my finger nail it kept growing. I ended up removing the entire coat of Bona in one sheet 32 x 96. I then applied a coat of XIM bond enhancer and three coats of Bona Traffic. All is well and came out great
6/9/17       #4: epoxy sealer under 2k poly? ...
Nick
Some more info;
this project has a high (unavoidable?) possibility for product failure; l'm finishing (2) sinks turned from western bigleaf maple burl both with live edges and plenty of bark on the top edge and outside of the bowls.
l've finished about a dozen walnut ones for this guy already using 2 different finish schedules over the years with great results (one is going on 6 years old and looks new :note, it doesn't get much use:)
our original method was; 1 coat Smith's CPES, 4-5 coats Rudd Prothane
The schedule now is; MLC Polarion sealer followed by 3-4 coats of Polarion 2k poly.
The walnut sinks did not have a live edge.
So because of the softer wood and bark on the maple sinks l've brushed and poured on/in 1 coat of Smith's CPES and was hoping to use the 2k poly as I was thinking I could use the slow reducer and a brush to work the finish into the nooks and cranies of the bark to help keep the water out...
6/9/17       #5: epoxy sealer under 2k poly? ...
Leo G
I've brushed Polarion Sealer on before trying to fill oak grain. It does work.
