Sheen for inside boxes
6/13/17
Vince Member
Preparing to finish my own ply insides rather than typical (for me) pre-finished.
Spraying SW CV.
Is bright rubbed, or dull more common?
If it could go either way, I would assume dull to be less work?
6/13/17       #2: Sheen for inside boxes ...
Leo G
I typically use satin.
6/13/17       #3: Sheen for inside boxes ...
Vince Member
Ok.. I would call SW dull rubbed a satin.
6/14/17       #4: Sheen for inside boxes ...
RobertJ
Sheen is often designated by a number:
5% to 90%.
25 may be Satin and 40 may be semi-gloss.
Others, pleas chime in!
6/14/17       #5: Sheen for inside boxes ...
Vince Member
The pre-finished I was getting seems closer to a semi. Maybe cleans better?
6/14/17       #6: Sheen for inside boxes ...
Nick
l'd agree with Vince. I use the SW medium rubbed when I need to match the sheen on pre-finished maple.
6/14/17       #7: Sheen for inside boxes ...
Bob Niemeyer  Member
Inside drawers I like nothing higher than a 20 sheen. Very nice furniture has lower sheens in the drawers boxes, it should duplicate a dull waxed soft touch.
Most cheap crap from china furniture has shiney drawer boxes.
Also I dont use CV in drawers, to much off gassing. I use Nitro on furniture and 2k PU on kitchen drawers.
6/15/17       #8: Sheen for inside boxes ...
Vince Member
I could switch to vinyl sealer, then 2 coats of pre cat laq.
Or just 2 coats of pre cat laq.. I have used this with good aesthetic results on drawers before..
I thought I was doing them a favor using CV, for durability. Is CV common inside boxes and drawers?
Any prompt input is valued, as I need to order the finish soon to keep on schedule.
6/15/17       #9: Sheen for inside boxes ...
Vince Member
By the way, these are kitchen cabinet boxes.
6/16/17       #10: Sheen for inside boxes ...
RobertJ
May be off topic, but what are you saving in dollars and cents when comparing a sheet of UV cured ply, to one that you have to spray yourself?
6/16/17       #11: Sheen for inside boxes ...
Leo G
You aren't saving anything. It'll cost more. But if you're good at spraying it'll give you a much nicer interior and since it wasn't finished and shipped all over kingdom come, there will be no scratches. Plus the UV finish is very thin so it is likely to wear out before a finish you apply yourself at proper mil specs.
6/16/17       #12: Sheen for inside boxes ...
Vince Member
What Leo said.
I come from remodeling, and do occasional cabinet projects. A few a year. So I am after quality, rather than production.
The pre-finished I was getting did not look so great. This veneer core maple ply is a much better product, plus the finished ends (there are about 8 in this project) match better this way.
I also like how I can be rough on the sheet, dadoing, shelf pin drilling, etc. and then da sand it all smooth.
I still wonder if I should use pre cat or CV though.
6/16/17       #13: Sheen for inside boxes ...
Vince Member
Yet another reason I failed to mention - I like to put nosing on the shelves.. they match better when using raw, quality hardwood ply, then clear everything.
6/16/17       #14: Sheen for inside boxes ...
Leo G
They both stink for a while. The CV is 85% cured in 24 hours and the rest in 2 weeks. The precats generally take 30-40 days to fully cure.
I do CV.
6/16/17       #15: Sheen for inside boxes ...
Vince Member
I move slow, so it will have plenty of time to stop smelling before actually being used. Plus some remodeling has to take place before install. plenty of time.
I will be glad to keep it the same finish I am already using, plus happens to be a very durable choice.
