pressure pot
7/25/17
bob
I have a binks conventional pressure pot and not sure how to back flow to clear the lines after using the system.
7/25/17       #2: pressure pot ...
Tyler
Depressurize the system, take an air nozzle with a rubber tip and hold it to the tip of the gun. Pull back the trigger all the way, and then release air into the gun. This will force 80-90% of the material out of the lines into your pot.
7/25/17       #3: pressure pot ...
Tim G
Or do as above, but just loosen the air cap and cup your hand over it, squeeze handle. Material will back flow, you'll see it bubble up in pot.
7/25/17       #4: pressure pot ...
bob Member
sounds easy enough, thank you both Tyler and Tim.
