Finish for reclaimed wood
9/12/17
Carmine Member
We use reclaimed lumber at the customers request for various projects. Cabinetry, barn doors etc. We try not to affect the patina too much. Compressed air and bristle brush just to remove any grit.
We prefer that it looks like it has no actual finish applied. Is a flat CV a good option?
9/12/17       #2: Finish for reclaimed wood ...
tyler
the best finish for making it look like there is no finish is probably an oil. It changes the color of the wood, but has no film build.
Another option is a waterbased in a super flat sheen, it looks almost like nothing is there
9/12/17       #3: Finish for reclaimed wood ...
RobertJ
I second the suggestion that a 'waterborne' lacquer is your best option. Little color change, and low odor.
9/13/17       #4: Finish for reclaimed wood ...
CV likes to applied to flat panels. It dislikes excessive film thickness.
I agree with the waterborne laquer. You can slather it on and it doesn't care. Its truly water clear. Flat as possible. Its also very protective against nearly everything.
9/13/17       #5: Finish for reclaimed wood ...
Carmine Member
Thank you guys for your suggestions.
9/13/17       #6: Finish for reclaimed wood ...
Shane
you should look into an acylic polyurethane... like Sayerlack TZL7105 5 Gloss..Through the Sherwin Williams distributors. Can be sprayed as a self seal and if you don't hog it on it will not shift the color/wet out and will appear unfinished...... Milesi makes an acrylic poly that acts the same way in a low build/low gloss also... Both are very good products and are a post catalyzed... very durable.
