Over spray?
11/8/17
Jim Member
Finished some cabinets in my shop with catalyzed lacquer. Came out great but have a few doors that have a little something I can feel when I run my hand over them. Maybe a little over spray or something.
Any ideas from anybody on how to get rid of that?
Thought about maybe triple ought steel wool and some orange oil but thought i would run it by you guys first.
Any help greatly appreciated since it's my own kitchen and my wife is looking over my shoulder.
11/8/17       #2: Over spray? ...
Leo G
My go to trick is a brown paper bag. I've heard that it has an abrasive equivalency of 2000 grit.
Give the CV about 1 hour to dry and give it a good rub on the areas that are a bit rough. It's better to do it earlier. Even if you don't get it glass smooth after it cures and stretches it will get smoother.
I like to use the lunch bag paper bags.
11/9/17       #3: Over spray? ...
JeffM
If it's lacquer, why not just scuff with an abrasive sponge and re coat?
11/9/17       #4: Over spray? ...
Robert Member
Try fogging on some Lacquer Thinner with a tad bit of retarder in it. That will melt in the over spray without leaving a sheen difference that the burnishing may leave.
Another option to using a paper bag is a piece of Wax Paper.
11/9/17       #5: Over spray? ...
Jim Clark
A "clay bar" that's used for cars works
good if it's something you can get
wet.
11/13/17       #6: Over spray? ...
Mike Fuson
Worn out high flex sponge pad.
11/16/17       #7: Over spray? ...
Willem Martins  Member
Website: thelastwoodworker.com
Irrespective of over-spray or not, I use a cotton cloth slightly damp, with a tiny amount of automotive rubbing compound (1500 and using too much will leave some in the pores). A quick rub down taking almost no time leaves the finish smooth and improves the look.
