dust removal -- 0 --
11/25
When sanding between coats of CV we use vacumn sanders, than blow off with rags and air. Once in booth right before spraying i use air and a clean rag to wipe again. It still feels like a micro of dust is presence, what is everyone using to wipe? Will do not use tack racks and prefer not to. Thank you for any suggestions.
11/25 #2: dust removal ...
Just use air and my hand. Usually it takes two passes before it feels ready.
When I'm spraying 2K poly I'll use Denatured Alcohol and a paper towel, then blow off again.
11/25 #3: dust removal ...
I found that rags would leave lint caught in the grain. Now I blow off in the booth and have a fine hair brush to lift dust from the pores. In winter static electricity becomes a problem with CV which I haven't solved.
11/25 #4: dust removal ...
They have ion blowers to combat static but they aren't cheap.
Denatured Alcohol naturally relieves static.
11/25 #5: dust removal ...
The fine hair brush just might be the ticket, able to get into corners and ok as long as no brush hairs get left behind, thank you for your replies. We have a portable ion that connects to the air line but to be effective they recommended low air pressure. Kind of defeated the purpose .
11/26 #6: dust removal ...
We use air and on flat surfaces (dining tables and conference tables) air and tack rags. We buy the 2k compatable tack rags.
We also in the winter time use a Simco Cobra Ion gun, works like a champ. If in areas where it gets cold be sure to watch low humidity in your shop, we try to keep it over 45%.
I dont like rags as they can carry more dirt than they remove.
On small tops we only use air and the hand wipe, like Leo says it does take a double wipe.
Many times I do wet the floor to help keep the floor dust also at bay.
11/26 #7: dust removal ...
I use Endust sprayed on a rag.
It pulls all the dust out.
and NO it doesn't bother the finish.
I also use it on cars before painting.
Been using it for over 10 yrs and never had a problem.
11/26 #8: dust removal ...
Website: accentpainting.com
I have been using Endust on CV and precat for 4 years now. No problems to date. Always do a test first is a safe practice to follow. Air and your bare hand is always a safe bet. It also allows you to feel where an area might need additional sanding as well.
11/27 #9: dust removal ...
vac with a brush head, it does a better job than your hand, and compressed air for the nooks and crannies
0 --
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Galleries
Project Gallery
Sawmill Gallery
Shop Gallery
Shopbuilt Equipment Gallery
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
