5 Gallon Dispenser
12/7/17
Didnt find anything in the archives. Are any of you using some type of pump dispenser or a valve/spigot type arrangement (pail on its side) to dispense for 5 gallon pails? I get tired of hooving the bucket around and the mess/waste using a spout. The pump dispensers I most commonly see seem to be light duty and it would seem like pumping a large quantity of material would be just as much work. We are waterbourne but just looking for a better option.
12/7/17       #2: 5 Gallon Dispenser ...
Charles Member
Cannot help directly with your question. We avoid the issue by only purchasing one gallon containers. When we purchase enough at a time, we can usually get a price break to match the 5 gallon price. This also keeps the product fresher, which works for our particular operation. And, the one gallon containers fit into our 2.5 gallon pressure pots.
12/7/17       #3: 5 Gallon Dispenser ...
chris
get yourself a pail tipper.
can find on amazon.
easy to control flow
12/7/17       #4: 5 Gallon Dispenser ...
Jr Lee
Website: http://leecabinets.com
Hood Finishing has carried them.
hoodfinishing.com
12/11/17       #5: 5 Gallon Dispenser ...
Thanks guys. We do usually buy in gallons for the reasons you mention Charles. We have a large project on deck and the 5's are better for us with the quantity of material we will be going through. We keep a few clean cans to go in pots but everything gets strained anyway so coming straight out of a pail is no issue. If we're not going to be using finish for a while we top off the pail with argon and that helps a bunch with the freshness but most generally we just try to not sit on finish for long in the first place.
I keep waiting for some finish supplier to start supplying material in a wine box type affair. Heavy cardboard box with a collapsing bag inside. Keeping the solids in solution may be an issue but Id imagine if you moved material through the shop quickly it would be much less waste in the landfill.
Thanks again.
