Mahogany grain filler/glaze
1/15/18
dub
I'm about to start finish samples to "match" the attached photo. The project is built with African Mahogany and will be sprayed with pigmented Conversion varnish (self sealing color coat), sanded, glazed/filled and then clear coated.
Q). Would anyone recommend grain filler over glaze? or Breakaway glaze over wiping?
Would breakaway glaze get down into the pores of the wood?
Thankfully I haven't had to do a painted and glazed project in a while but always disliked trying to leave "just the right amount" of glaze and getting doors and face frames the match perfectly on inset jobs. I'm looking for input on the easiest/most consistent process.
1/15/18       #2: Mahogany grain filler/glaze ...
Wiping glaze with a paint thinner wipe to clean it up. Looks like they also sanded the pigmented paint a bit because you can see the corners are bare looking.
1/15/18       #3: Mahogany grain filler/glaze ...
Shane
I'll tell you what I'm seeing from the photo is a very watered down primer sprayed. Scuff sand lighly... burn through edges and a very watered down black/raw umber oil based glaze wiped on and cleaned off.. vinyl seal scuff and light low sheen topcoat...
1/15/18       #4: Mahogany grain filler/glaze ...
You better experiment with thickness of the coat of conversion varnish. A thick coat will do a nice job of filling pores. To kill the color of your mahogany, you may even need two coats.
1/15/18       #5: Mahogany grain filler/glaze ...
dub
thanks for the replies.
I will experiment thinning the CV to get enough color, without filling the pores. I thought about doing the color in primer/sealer, but worried the glaze wouldn't wipe clean enough and effect the color too much.
Thankfully, I'm not trying to match something in the room, just the color/feel of the showroom display.
thanks again.
1/16/18       #6: Mahogany grain filler/glaze ...
Shane
I would approach it as follows:
Sand raw up to 180 grit
Seal with vinyl sealer reduced 50%
Scuff lightly to smooth out any raised grain and smooth it out.
Spray a heavily reduced white primer at a very thin film thickness.. just enough to cover without having the pores fatten up.
Scuff sand and burn through the edges/corners.
possibly another vinyl seal reduced even further so your primer doesn't shift too bad with the glaze.. like a wash coat of vinyl
Glaze with a very reduced oil based glaze of raw umber/and a little black.
light coat of precat flat sheen.... let it flash of and then a full wet coat of flat sheen precat..
