Best finish for wood veneer snowboard
1/22/18
Rob Kerr
I have purchased a snowboard that was a failed manufacturing experiment. The topsheet (top of the board) is a nice walnut veneer that is saturated with epoxy and then pressed to the board core. On this board, they were trying a new gloss finish and it was a failure. I don't know what they used. My plan is to sand down to epoxy layer and refinish. My question is: what should I finish with? I'd like a clear satin finish - but it needs to be extremely durable and withstand flex, vibration and extreme cold.
Thank you in advance for any guidance.
View higher quality, full size image (800 X 1067)
1/22/18       #2: Best finish for wood veneer snowboa ...
Bart
West Marine epoxy should do the trick.
1/26/18       #3: Best finish for wood veneer snowboa ...
Joe Calhoon
My son and I build a few skis just for our own use. I have seen some nice wall hanger skis with a high gloss marine finish. They look good till they get a few scratches.
We use Osmo on the ones we build. Usually apply it once or twice a year. Its low luster and close to the wood and does not show scratches or dings much. We sometimes use a Sirca wax effect finish on doors and windows and think that would be good in this application also. Hard to describe, its sort of a water base oil finish.
Building, we coat the veneer top sheet with epoxy before pressing just to get good saturation then sand it back to the wood for finishing after.
2/16/18       #4: Best finish for wood veneer snowboa ...
Duane
Might won't to try 2k exterior eurothane.
