RE: Walnut Color fade?
1/22/18
Tommy
Does the color of walnut for a table fade over time?
Is it better to apply a light walnut stain or finish to bring out the colors? If so, what type and what finish?
1/22/18       #2: RE: Walnut Color fade? ...
Usually when I do walnut I get a can of American Walnut from ML Campbell. I thin it 50-50 with their clear stain base. Beautiful color.
1/23/18       #3: RE: Walnut Color fade? ...
Paul Miller
Walnut is one of the few wood species that actually gets lighter as it is exposed to the sunlight. I would recommend a stain.
As for finish, you have lots of options. It really depends on your experience, equipment and the use.
1/23/18       #4: RE: Walnut Color fade? ...
Kevin
I do exactly as Leo. It seems to be closest to “natural walnut” but with no fading over time.
1/24/18       #5: RE: Walnut Color fade? ...
Matt
Agreed with the above, walnut will lighten with exposure to the sun.
In our shop and market, this is not considered a defect, it's part of the nature of the wood, and we do not stain any job that calls for natural color walnut. We just clearcoat it.
We have had a number of times where the natural color of walnut wasn't quite what they wanted and we ended up staining it to make it more black, or more golden, or more reddish. Those jobs don't fade nearly the same rate, nor nearly as light when final.
Fortunately walnut does take stain rather well.
2/3/18       #6: RE: Walnut Color fade? ...
scott
Leo,
Is that the clear spray stain base by ML Campbell that you mix with the American Walnut. I haven't used ML Campbell for about 4 years as the dealer close to me changed products, but now there is a new supplier. Thanks
2/3/18       #7: RE: Walnut Color fade? ...
Clear stain base. Wipe on.
2/4/18       #8: RE: Walnut Color fade? ...
scott
Leo,
Thanks for the info, I have to build a vanity and some shelving out of Walnut, so I am going to give that a try.
2/4/18       #9: RE: Walnut Color fade? ...
The finish is still wet, but it'll look this color.
View larger image
