Throat Seal Lube and Fisheyes
1/25/18
Kevin Member
Can anyone tell me if the throat seal lube on a kremlin pump would cause fisheyes if it came into contact with the finish? I have a cartridge that needs replacing and am getting paint on the suction rod. I am also having an issue with fisheyes, wondering if thats the cause. Throat seal lube I am using in made by CA technologies.
1/25/18       #2: Throat Seal Lube and Fisheyes ...
Robb Parker  Member
There is no doubt that if your getting paint on the rod, oil is getting into your finish. There is also no doubt that oil in the finish will cause fish eye and adhesion problems.
1/25/18       #3: Throat Seal Lube and Fisheyes ...
Kevin Member
I talked to a guy at Ca tech earlier. He told me there was nothing in that oil that would cause fisheyes. In fact, he told me when they were first testing it, they dumped a gallon into a five of lacquer and sprayed, no issues.
1/26/18       #4: Throat Seal Lube and Fisheyes ...
Shane
try it yourself....... dip your finger in the lube and spread it all over a sample board that has been previously sealed.... wipe off the excess with a rag and shoot over it..... no fisheyes with kremlin or the cat
Now take some of your old lady's deodorant into work and rub it on a sample board and wipe it off and shoot it... fish eye soup.
when in doubt check it out..
1/26/18       #5: Throat Seal Lube and Fisheyes ...
Shane
ps..... the same with wd-40. it does not cause fisheyes. We actually keep wd-40 in a spray bottle to keep our control samples "wetted" while doing color work with our finishes. We constantly compare wetted colors while spraying and color correction.
1/26/18       #6: Throat Seal Lube and Fisheyes ...
Robb Parker  Member
Kevin,
Not to get in a pissing match with a CAT rep, but that is not my experience. We run two CAT pumps and their oil for years. One has been rebuilt for just the reasons your experience. Solved our problems. Guess they are the "experts" though.
1/26/18       #7: Throat Seal Lube and Fisheyes ...
Brian Member
The lubrication Kremlin offers with their pumps is DOP (dioctyl phthalate plasticizer), a common resin in some coatings systems.
I would be astounded if CA Tech didn't have a similar lubricant.
1/28/18       #8: Throat Seal Lube and Fisheyes ...
Herb Johnson
A lot of throat seal lube also are mineral oil based , you could drink the stuff, a lot of good points made on this thread
