Regulator for gravity gun question
2/21/18
Duane Slaymaker Member
I recently switched to a Kremlin gravity feed cup gun for some of my finishing. I originally placed the regulator at the gun inlet as is common. This is very cumbersome for tight areas. I now have reconfigured with a wall mount regulator. There is a 25 ft. Air line between the reg. And the gun. Question is.... is there a performance sacrifice by doing this. It seems to be working but I am new to this type of gun and have nothing to compare to.
Thanks in advance !!
2/21/18       #2: Regulator for gravity gun question ...
maple leaf
the gun has an air adjustment knob at the bottom. you could do all your finer adjustments there. lot of people keep the regulator away to reduce weight. it will not affect the performance of the gun.
2/21/18       #3: Regulator for gravity gun question ...
Shane
set the wall reg to about 55 psi and use the cheater knob on the gun to dial it the rest of the way in... This way your not killing the felt trigger pull with shop air at full blast but still have some adjustment to choke the air down to atomize correctly with the cheater...
2/21/18       #4: Regulator for gravity gun question ...
Jim Clark  Member
make you a removable gage like this.
View higher quality, full size image (2048 X 1360)
2/21/18       #5: Regulator for gravity gun question ...
You can get mini regulators that are about the same size as the gauge.
2/21/18       #6: Regulator for gravity gun question ...
Bob Niemeyer  Member
There are charts that show pressure drop based on hose size and length. Google search for one.
Also remember static pressure will be the same anywhere in the system after regulator, always check flow pressure when trigger is pulled on gun. Cheaters on the gun are only for intermittent use and should always be completely open.
Jims gauge set up would work real nice and get you very close to desired pressure.
2/22/18       #7: Regulator for gravity gun question ...
Website: http://dswoodshed.com
Thanks for all the input so far. Sounds as if I am not doing anything that is forbidden. I think I became concerned recently when spraying oil based paint. I very rarely do this (thank God) this kitchen facelift job required painting existing cabinets and therefore applying the same to new doors, crown mold. Etc. The O.B. Paint is much thicker then the conversion var. that I typically spray. I became concerned when I had to increase reg. Pressure to 50-60 psi to atomize the paint. I also had to add thinner. Makes me REALLY appreciate conversion var.
2/22/18       #8: Regulator for gravity gun question ...
Jim Clark  Member
Keep in mind most regulators at the gun will restrict CFM, that's why I like the removable gage. I can adjust psi at the compressor while watching the gage at the gun and then remove the gage.
That PSI reading should always be with the gun trigger fully pulled.
