Dipping an oil / varnish blend
3/1/18
Ben Aroh  Member
I manufacture a small product, and am looking to switch to a "dip-able" oil/varnish (tung oil, danish oil, etc).
I have been using shellac & a WB topcoat for the past year, but want to experiment with a "closer to the wood finish".
The product is small and easy to dip. Starting in March I will be making them out of walnut - see the related link.
I have little experience with oil rubbed finishes (and maybe I'm barking up the wrong tree). Would love something that builds a low luster in 2-3 coats.
Products
3/1/18       #2: Dipping an oil / varnish blend ...
Ben Aroh  Member
I should add- something that can be coated 2-3 times in 24hrs is ideal.
3/1/18       #3: Dipping an oil / varnish blend ...
nick
Dalys satin Pro Fin might be just what you're looking for. I believe it's a urethane modified tung oil... 4 hour recoat, just dip, hang to drain & dry, sand with 320 soft sponge, dip and either wipe the excess for a lower sheen or hang dry without wiping for a higher sheen. 2 coats is usually enough but 3 coats with sanding between coats will give you more build & depth & a smoother feel.
To insure you don't burn down your shop, keeping track of your pro-fin soaked rags is a must,,,either air dry hanging on a line or immerse in a bucket of water,
3/1/18       #4: Dipping an oil / varnish blend ...
Ben Aroh  Member
Thanks - I'll give it a shot. Is this product similar to ZAR?
3/1/18       #5: Dipping an oil / varnish blend ...
nick
Don't know, I'm not familiar with Zar.
3/1/18       #6: Dipping an oil / varnish blend ...
They don't say anything about tung oil on the spec sheet. It is over 40% solvent though. It also says 4-8 hours drying time.
3/1/18       #7: Dipping an oil / varnish blend ...
nick
Rich makes a couple of good points; air movement and heat are necessary to get your dry times closer to the 4hours mark and yes the stuff is loaded with paint thinner so some ventilation is a very good idea too.
3/21/18       #8: Dipping an oil / varnish blend ...
cwwoodworking
Website: cwwoodworking.com
Have you considered spraying a dull solvent product? 2 coats, 20 minutes per seems like it would work for your product.
WB products, IMO, cant achieve that low luster look like a decent solvent.
3 coats of dip/wipe in 24 hr, I dont think is realistic.
