AAA with catalyst pump
3/17/18
Dan
Anyone using a AAA with the catalyst added as you go. Thinking it should save product. Any reviews would be appreciated. Make? Model? Trying to justify the cost!
Thank you
3/18/18       #2: AAA with catalyst pump ...
Bob Niemeyer  Member
Companies that spray PU's will use plural pumps.
What do you plan to spray and how much?
Lot of factors to calculate your savings and your ROI.
3/18/18       #3: AAA with catalyst pump ...
Dan
I spray about 10-15 gal per week of CV.
3/20/18       #4: AAA with catalyst pump ...
Shane
that's not enough material sprayed to justify the cost..... we use antistatic bucket liners by "Payliners" and catalyze only the material needed to complete the spray out on hand.. 1/2 gal 1 gallon 2 1/2 gallon just depending on what's in front of the finisher for a few hours of spraying... much less material wasted... you can always walk over and mix a short batch to finish up... We run 8+ open face booths 52 hours a week ... couple hundred gallons a week at times and don't use ratio pumps for catalyst.. It's just bling and eventually it will fail and cost you downtime if it starts acting up and gets your ratio out of whack. mix as you go and toss the liner..
