post cat problems
4/16/18
Patrick Member
spraying chemcraft post cat satin and matte and getting little "buggers" in finish:
Assuming:
-gun dismantled and cleaned
-filtered 180 microns
-proper mix
Right now just wash coating - reduced 10% and retarded 5%
using a fuji turbine - is the heat from turbine causing this? never had these problems with reg. air. This is not a dust or environment issue.
Help!
4/16/18       #2: post cat problems ...
mastercabman Member
I never liked turbine sprayers
It does get hot
Do you have pictures of those little boogers?
4/16/18       #3: post cat problems ...
Bruce Member
Try reducing air to a minimum and keep 6-8 away from what your spraying. You will find with excess air it will tend dry and leave boogers
4/16/18       #4: post cat problems ...
Patrick Member
When I reduce air have trouble with atomizing but will try this. Here are the little boogers
4/17/18       #5: post cat problems ...
CraigM
Could it be solvent pop? It looks like heavy coats on grainy wood, although retarding 5% should have helped. How fast is your thinner? Have you tried spraying it on a glass sample or piece that doesn't have such a deep grain?
4/17/18       #6: post cat problems ...
mastercabman Member
Are you using a sealer?
It could be solvent pop especially on open pore wood like oak
Try it on a piece of MDF
4/17/18       #7: post cat problems ...
Shane
that's not boogers or crap in your finish...... It's air entrapment on a very open pore wood..... your finish is applied to heavy (Wet Mils) and is not reduced enough... try reducing and retarding ... spraying much thinner coats...... Sell your turbine to an onsite touchup guy and invest in an air assisted airless rig and never look back.... it will pay for itself in quality.. cleanup... ease of use in no time over a turbine. Turbine are just ancient and way too slow.
