Spray gun for Dyes and Toners
5/14/18
John Member
Up front, I spray less than 5 gal per month. Much of the work I do involves WB dyes and shellac based toners to color match existing work. Shellac is the only solvent based product I use; all my topcoats are WB.
My current Qualspray gun, which draws around 8 cfm at 29 psi, is pretty versatile but I get some pulsing when spraying dyes and toners and that gives mottled color. I compensate by spraying at least two coats but that does not completely eliminate the non-uniform look. I had similar issues with the low end gravity feed HVLP gun I first used, which makes me wonder if the problem might be in my air line and/or filter or regulators.
I'm interested in what you folks recommend for spraying dyes and toners on furniture and cabinets with the most important characteristic being uniformity. For info., my compressor can handle 11 cfm at 40 psi. What should the piping size be for this flow? Thanks very much.
John
5/14/18       #2: Spray gun for Dyes and Toners ...
John Member
Another piece of info., my compressor, regulated at 90 psi outlet, is about 50 feet from the secondary regulator, and that is typically set at 29 psi. I use a 20 foot 3/8" hose from there to my spray gun.
John
5/14/18       #3: Spray gun for Dyes and Toners ...
mastercabman Member
John
When you say pulsing,is it like spitting?
Or it's spraying a little more or less?
Are you using gravity gun?
Is it set up with PPS cup.
Check your air cap and make sure no holes are clogged up
Also I like to use mini regulator at the gun
5/14/18       #4: Spray gun for Dyes and Toners ...
John Member
A little more, a little less, not spitting. I had this problem first with a low end gravity feed HVLP conversion gun, and now with my mid range gun with a pressurized 3M PPS cup. I first thought it only happened when the internal liner approached empty but I realize now that it happens even when the liner is full.
The air cap is clean. I used a mini regulator on the inlet of the gravity feed gun. The PPS cup on my newer gun has it's pressure regulator at the gun, so I have the gun air regulator 20 ft upstream.
Thanks,
John
5/14/18       #5: Spray gun for Dyes and Toners ...
nick
have you cleaned the fluid passage and nozzle lately (both inside and out)? One dried piece of crud at the tip on the outside or anywhere on the inside of the nozzle can even make a Sata spray like a $50.00 spray gun.
When it comes to spraying dye (SW universal dye thinned with DNA) I use a Devilbiss compact gravity gun with a 1.0.
For WB toners (1 to 1 finish to water) I use the same set-up as the dye.
For solvent based toners (1 to 1 finish to butyl acetate); I use a Sata 2000B with a 1.4 but I crank in the needle until the fluid volume is where I want it. For spraying toner I'm looking for the a gun with fine atomization and even particle distribution and then spray it at the lowest air pressure where the gun can maintain those attributes especially if the piece has any depth or profiles.
5/16/18       #6: Spray gun for Dyes and Toners ...
Herb johnnson
Buy an Iwata gun with the tulip tip stain will look like a spray and wipe not cheap but worth the money
Good luck herb j
5/16/18       #7: Spray gun for Dyes and Toners ...
John Member
Thanks for the feedback, all. I'm doing a complete soak and cleanout on the gun. I don't see anything in it, but I'll know it's clean when I'm done and if the problem continues then I'll know it's with the air delivery system. I'm suspecting the problem might be with my step down regulator, 20 feet before the gun. I had a similar problem with the last regulator when it developed a leak. This one seems fine, but the problem is back, so ....
I will look into the guns you all recommended, too. I start to choke when it goes North of $500, considering I used to get pretty darned good results with a $20 throw away gun, but I'm willing to spend the money if the results justify it. Anyone use a CA Tech. FE Line HVLP gun? Their literature says it's made specifically for dyes and toners.
John
5/16/18       #8: Spray gun for Dyes and Toners ...
John Member
As I was disassembling the gun more fully to soak it this morning I found the packing nut behind the trigger was completely loose. I think I've found the source of the problem.
The gun was pretty clean inside when I looked inside it after disassembly. It's really clean now.
John
5/16/18       #9: Spray gun for Dyes and Toners ...
mastercabman Member
John
Hopefully that was the problem
If something is loose it could bring air into the nozzle and can make it pulsing as you described
As for the FE LCFM spray gun
You can spray all kind of coating
You just need to get whatever size nozzle/needle for the task
I have one and sprays very nice
Also it runs on low CFM
