Smallest field spray setup. Post cat.
6/26/18
jd Member
I am trying to put together the smallest spray touch-up kit I can. My manufacturer uses post-cat urethane (they will supply me for color match) I do mostly inset work w/mortised hinges and occasionally I have to re-gap a door then reapply finish. Anything bigger goes back to the shop. How small and compact can I go? Compressor? Turbine? Airbrush? Aerosol? Thank you for any advise!
Josh
6/27/18       #2: Smallest field spray setup. Post ca ...
Robert Member
A Preval Sprayer is quite small. Pretty handy to have a few in the touch up kit. Better than the aerosol spray bombs Mohawk and other suppliers carry. No need for a compressor if your only doing a few repairs daily.
6/27/18       #3: Smallest field spray setup. Post ca ...
JoeW Member
I have been using a small compressor and an airbrush. Once I got the feel of using an airbrush, the resulting finish has been very good. Just make sure you go with an airbrush that has detachable fluid bottles.
6/27/18       #4: Smallest field spray setup. Post ca ...
jd Member
@JoeW
I was hoping that someone would suggest an air brush. I had concerns about viscosity. Would the Post-Cat be too heavy? Can u recommend a good airbrush?
Thx JoeW
6/27/18       #5: Smallest field spray setup. Post ca ...
JoeW Member
I have an Iwata Eclipse HP-BCS. Only trouble I had with viscosity was learning how much to reduce the finish to have it flow and leave a smooth finish. You have to play with pressure and thinning a little There are tutorials on line for it and a little practice and you'll pick it up fast.
