washed grey color
6/28/18
mauricio poli Member
Website: http://www.gruposayer.com
Hi everyone!
I need do match this washed grey color on a furniture made with pine, maple, poplar, birch; without using a glaze. In this photo someone use a toner, then a glaze, then the clear finishin. How could I get something similar using only no-wipe stains ? Anyone ever tried to do this? Thanks a lot !!!
washed_grey.pdf
7/3/18       #3: washed grey color ...
Kris Member
That looks doable to me, but might take a few more samples than normal to get the colour thin enough.
I'd do a washcoat, and then play around with thinning out the stain with either thinner or stain base to get the right consistency
7/3/18       #4: washed grey color ...
Thanks Kris ! I am still working on this, I´m doing a grey NC wash coat , sanding, and a grey wipping stain. I tried to do in just one no wipping stain, but it is difficult to achieve always the same color. If it was in only one wood, it would be great !
Thanks for your time.
7/3/18       #5: washed grey color ...
nick
The first step would be to equalize the color of the woods, I'd use a pale grey stain with quite a bit of white and a touch of yellow and brown... let's call it a thin creamy grey (more grey than creamy).
2) spray on a thin wash coat; 4 or 5 parts thinner to 1 part finish/sealer...practice on a test piece until you get the ratio and volume right.
3) spray on your darker grey stain, I'd probably go thin with this too, so you get your color in 2-3 passes instead of going for the one pass and done.
Good luck!
7/9/18       #6: washed grey color ...
Thanks Nick! I have done this and worked well.
