Oil based paint will not dry, over tinted?
7/18/18
Matt
Hello all, I have a kitchen island I painted in oil based paint(customer request). After six days the first coat is still not hard enough to assemble. It has two coats of oil based primer that dried and sanded good. The paint is dry to the touch, but I can still push a finger print into it. A lot of the parts are vertical surfaces so I didn’t apply to heavy or there would be runs. I have the heat set to 78, a fan circulating air, and a dehumidifier going that says RH is 35. I’m wondering if the paint store over tinted the paint? Anyone’s thoughts or insight would be appreciated. Thanks
7/18/18       #2: Oil based paint will not dry, over ...
Shane
Your using an oil paint designed for metal exterior substrates on an interior wood island....? Good luck getting that finish anywhere close to not marring for a long time..... here the power of google tells us what your working with... all the info you need is on the TDS sheet... technical data
http://www2.benjaminmoore.com/DownloadBinaryServletTDS?np=productcatalog_d
atasheets/tds/TDS_0235&fileName=20110615 Z235 TDS US OKF.pdf&propertyName=multidatasheet[1].data_sheet_file_en_US
7/18/18       #3: Oil based paint will not dry, over ...
Matt
The paint is the interior low luster enamel for walls and trim. Quite a few homes around here have had there cabinetry painted using this paint, most of them 100 year old summer cottages, and the owners want a period look. I don’t see where it’s meant for exterior metal. Can you specify where in the documents you read that? My experience is 4 to five days of drying is all that’s needed. Thanks
7/18/18       #4: Oil based paint will not dry, over ...
Shane
there were two data sheets and your correct... the wall & trim paint you have is indeed for interior. Other than that it shares the same exact data for application with the exterior product of the same name. That particular kind of finish is going to take weeks and weeks before it is tough enough to not feel gummy or indent with the tip of your nail. period.
7/19/18       #5: Oil based paint will not dry, over ...
nick
Not drying at 78 degrees with the humidity in the mid 30% and a fan in the room...yikes! The only thing I can think of is more fans.
From time to time I too get customers who want a brushed on oil-based enamel finish and for those jobs I've been using and having great success with 'Hollandlac' from Fine Paints of Europe.Brushes out and levels great (sprays great too) with a 16 hour recoat. On the down side the stuff is very expensive $160.00 for 2.5 liters (if I remember right) and even though it may be dry to the touch overnight that doesn't mean it's ready to stack & pack... for that it's more like 2-3 weeks.
7/19/18       #6: Oil based paint will not dry, over ...
Hi Matt,
You described a common practice in the Northeast. Builtin cabinetry with Bennie Moore oil Impervo. They like the brushed look.
In my experience it can take 1 week before you can touch two painted surfaces like shelves without peeling the paint.
Full hardness usually takes a 4 weeks. Fingerprints for the first 2 weeks.
We warn the builders and customers, but they still want the look.
Did you use any reducer? We typically use Naptha. You might have put on really thick coats.
I would give it a couple of more days before getting cray about it. Good luck.
7/19/18       #7: Oil based paint will not dry, over ...
TonyF
Matt:
I am not a finisher, just a retired cabinetmaker, but I wonder if spraying one more coat of oil paint with japan drier mixed into it might not help your situation.
I imagine the finishers will opine on why this may or may not work.
TonyF
7/19/18       #8: Oil based paint will not dry, over ...
Pat
Instructions say "Do not thin." Did you thin it?
7/19/18       #9: Oil based paint will not dry, over ...
Matt
Thanks for all the responses. I’ve used this product before, and it usually drys in two days before I reassemble parts. I did add 4 ounces of naphtha which I normally do. It is slowly getting better, and I don’t have to deliver till the end of next week so I think I’ll just wait it out. One of my concerns is how much tint can you add to this product, and does the large amount of tint slow the drying time significantly? I can’t find that information anywhere. Thanks again
7/20/18       #10: Oil based paint will not dry, over ...
It does say do not thin in the tech doc.
I'm not sure how it would be possible to spray the stuff without thinning. They also say its can be used as a 1 coat finish. Likewise we always use 2 coats.
I've never used an oil based/alkyd paint or varnish that did not require the use of a reducer to brush or spray.
As I mentioned before we have always used naptha for spraying and brushing.
The doc confirms 1 week for handling.
We switched years ago to Muralo Ultra wb for field applied finishes. Its a better product in every measure to products like Oil Impervo. Best part is it doesn't yellow.
7/21/18       #11: Oil based paint will not dry, over ...
robert johnston
Reading the tint profile, your Satin Impervo has almost 14 ounces of tint. And the Ultra base does not help, but is required to get the color to match.
One suggestion already stated was to add Japan Drier. Too late for that.
Next time, use FPOE (Fine paints of Europe) in Vermont.
Wait four weeks.....then top coat with above for more durability and a better finish for your client.
Or, use Epifanes Yacht Enamel!
