Bringing up cv sheen
7/31/18
Kevin Member
We did a couple of large walnut built ins shot in semi gloss cv. After install, I'm noticing a couple of areas that seem duller than others. Any recommendations for onsite buffing or polishing? I have used abralon pads up to 4000, but never on the face of cabinets. Any advice would be appreciated. Thanks.
8/23/18       #2: Bringing up cv sheen ...
Matt
Just simply rubbing it in the direction of the grain with considerable force, using a CLEAN, smooth cloth will often do this, if the sheen difference is NOT due to rough grain underneath. You definitely have to work at it, it's not a sudden change.
Any method of bringing up the sheen is bound to have a similar effect, in the opposite direction. You may have spots that look "shiny but noticeably a different kind of shiny".
