Water based Retarders
8/2/18
Jonathan Mahnken
My Chemcraft provider says that chemcraft doesnt package any retarder or flow additives for their waterbased line. He has instructed me to use Butyl Cellosolve(lacquer retarder) mixed with water 50/50 and add at 3 percent. He says for the stain however I should use Glycol Ether. Some sources I have looked up say that butyl cellosolve and glycol ether are the same thing. Is this true? or are they different chemicals?
8/2/18       #2: Water based Retarders ...
DannyB Member
Glycol ether is not a single chemical.
There are many ethers of glycol.
Butyl Cellosolve is one of them, also known as ethylene glycol monobutyl ether.
There is ethylene glycol monoethyl ether, ethylene glycol monomethyl ether, etc.
Here's a list of synonyms for Butyl Cellosolve:
http://www.commonchemistry.org/ChemicalDetail.aspx?ref=111-76-2
In general, if you look at that CAS number, anything with it, should roughly work in place of butyl cellosolve.
As for your problem:
Most water based stains (and a lot of paint) do use glycol ethers.
If the stain requires *any* glycol ether, yes, butyl cellosolve will work.
If you want it to be exactly right, usually the easiest thing to do is look at the MSDS of the stain, pick out the glycol ether (usually referred to by one of the names you find on the wikipedia page for glycol ethers), and go get that to use as a retarder.
As an example:
Target coatings WR4000 is a water based wood stain .
If you stare at the MSDS:
https://www.targetcoatings.com/wp-content/uploads/2016/05/WR4000-SDS.pdf
You'll
see Dipropylene Glycol Monomethyl Ether, which is a glycol ether.
If you look at the Target coatings water based retarder MSDS:
https://www.targetcoatings.com/wp-content/uploads/2016/05/SA5-SDS.pdf
You will see it's just Dipropylene Glycol Monomethyl Ether and water.
While a lot of the glycol ethers can be used in place of each other for these applications, i'm not sure i'd play around with this for a professional finishing job unless I had a background in chemistry (or the manufacturer told me it was fine to use)
8/3/18       #3: Water based Retarders ...
Shane
Propylene Glycol mixed at 5% will work just fine in all waterborne topcoats and stains as a retarder.......Obviously test samples first to be sure it doesn't act funny with your specific coating. It can be obtained pretty much across the whole internet because of it's uses for a wide variety of things.... Or you can buy it from general finishes as their extender.... they charge about ten times more because it's labeled general finishes extender...
Butyl cellosolve 1:1 mixed with distilled water.... stirred in well to a solution then add at 3% by volume to coating can be an option but the problems with butyl I've seen makes some coatings a little snotty/sticky and can cause the solids to coagulate on some coatings... this is where testing comes in handy.. Samples samples
8/3/18       #4: Water based Retarders ...
Bob Niemeyer  Member
Good Advice from everybody, but remember these are also the "cosolvents" in waterbased formulations. Use in very small amounts as you can throw the formulation out of wack real fast. Good Luck!!
8/3/18       #5: Water based Retarders ...
Jonathan Mahnken
Great info Guys. Thanks. If I buy pure propylene glycol do I need to cut it 1:1 with water before I mix it in to my coatings?
Shane I did notice that the coating was oddly tacky until cured when I tried the butyl cellosolve.
The other part to this is that 3-5% isnt all that much in regards to a wiping stain. With every other brand I typically max them out to the tune of around 15% just so they are pleasant to handle on larger pieces. except in the winter when I need them to speed up.
Is there anyone here who uses the chemcraft wb line who may be able to weigh in with any tips for the product?
9/24/18       #6: Water based Retarders ...
edge3
First of all Butyl Cellosolve is to be used in solvent based systems only.
You need Butyl Carbitol for W.B systems to retard and help with flow out.
