Finishing Redwood
8/3/18
Todd
I am working with a client to craft a 48 x 130 x 3 redwood slab table top. I have never finished redwood. The redwood is at 10-14 MC. The table will be used in an open environment in Southern California. It will not be outside.
My question is what finish would be best given the parameters. I am leaning toward Rubio Monocoat. I have sprayed MLC Polarion but not sure that can handle the potential movement of such a large slab in an open environment.
Thanks in advance.
8/3/18       #2: Finishing Redwood ...
Polarion comes in an exterior version which should have better properties for wood movement. Never used it myself.
8/4/18       #3: Finishing Redwood ...
nick
I live in Redwood country and have finished a lot of it. 10-14% MC sounds too high for finishing something that big with a film forming finish...you can count on that there will be some shrinking going on.
With that in mind, the Rubio Mono-coat just might be the ticket...I've never used it but I know a couple of guys that do and they swear by it, they even use it for floors (I'm a skeptic but like I said I've never used the stuff)
Also of note; Redwood finishes well with solvent borne products. but since redwood has a high tannin content finishing with WB's can sometime lead to surface staining.
Unless your customer cut down a tree on their property I'd bet it's safe to say a chunk like that cost a small fortune.
8/9/18       #4: Finishing Redwood ...
Dustin Member
Website: http://www.rhodeshardwoodflooring.com
Rubio Monocoat works great on Redwood. I do wood floors for a living and we use lots of Rubio and have used it on lots of different exotics and it works great. Another option that works well is using a universal sealer (aka dewaxed shellac) and then coating with an oil or waterbased finish of your choice.
8/14/18       #5: Finishing Redwood ...
Devin Dannat
Website: http://www.tungoilfinish.com
Check out our exterior polymerized tung oil sealer and medium lustre. www.tungoilfinish.com
we bring in raw tung oil and polymerize it here in our facility. This is a great exterior finish as it will flex and move with the wood during different levels of humidity. This product has zero resin and is 100% pure polymerized tung oil with a UV light absorber and fungicide added. Feel free to give us a call 1-800-322-1245
