Repairing Conference Room Table Finish
7/27/18
Tony Rampulla
At work we have two custom made oak veneer conference table tops that were finished using paste wood filler, lacquer sanding sealer, and then top coated with polyurethane. Obviously polyurethane should not have been used over lacquer, because now the topcoat is coming off. I'm looking for advice on how best to repair them. Should I just remove the poly by sanding, which if it's already "loose" shouldn't be that difficult, or should I use a chemical stripper and take everything off down to the bare wood? If I just sand the tops down to the lacquer sealer, what would be the best finish to apply over it? Thanks for any advice!
7/27/18       #2: Repairing Conference Room Table Fin ...
mauricio poli Member
It is very recommended to strip it all until you have wood again.
Clean very well before start finishing again.
8/9/18       #3: Repairing Conference Room Table Fin ...
Matt
Agreed with the above. Since this is veneer, I'd be cautious with a "sand it off" attempt, although this has it's merit, I've done it several times to kitchen tables without ever touching a chemical strip. Most polys (if oil based, and cured fully) sand off somewhat reasonably well as long as the joker that put it on didn't lay a 30 mil thick coating of it.
The obvious risk on the chemical strip is eating off the adhesive, and the risk of sanding it off is burning through the veneer.... so choose your poison lol.
8/9/18       #4: Repairing Conference Room Table Fin ...
Tony Rampulla
Thanks for the advice! I think a chemical strip is the best way to go to prevent sanding through the veneer. I have no desire to deal with that headache!
8/12/18       #5: Repairing Conference Room Table Fin ...
Hi Tony !
Please, be sure to do not use too much stripper. As Matt says, you have to take care to do not reach the adhesive. So, apply in small areas and small quantities each time, let it work some time and clean well. And then finish with sanding , until you have you wood again. Thanks Matt !!
