Finishing Torrified Wood.
8/27/18
I have a client that has purchased an entry door (pair) made from solid torrified Mahogany. I need to put a finish on it for them. I deal with MLC finishes and was planning on using Exterior Polarion. It'll be stained with the Woodsong II stain, then their Isolante sealer then the Polarion.
Is there anything I should know about the torrified wood that might be different from a normally dried wood?
I'm not as concerned about the finishing part as I am of the staining. I know torrified wood has the cell structure of the wood damaged when it is "over dried". I don't have a test pc of wood to experiment with so it's going to be one and done.
Anything to be worried about with staining?
8/28/18       #2: Finishing Torrified Wood. ...
Pete Anderson
Can you use the top edge of the door for a sample of the stain color?
8/28/18       #3: Finishing Torrified Wood. ...
Pretty much the only area I have. Bottom is covered with a weatherstrip.
My client is getting a sample square of the finish she wants. I'm hoping it's the same material. I can use the back as my sample.
8/31/18       #4: Finishing Torrified Wood. ...
TonyF
Leo G.:
Perhaps one of the suppliers of the doors can help answer your questions.
Hope this helps.
TonyF
Horner Millwork
