Urethane Moulding with Lacquer Finish
9/5/18
Jordan  Member
Website: http://www.jalvisllc.com
Need to spray a project with "Urethane Corbels" and Mouldings by Ekena. Can I spray them with lacquer?
9/5/18       #2: Urethane Moulding with Lacquer Fini ...
Brian Member
It's done all the time in new home construction, but I've yet to see a wood coatings manufacturer say that it would be OK to shoot lacquer on a surface like this.
9/5/18       #3: Urethane Moulding with Lacquer Fini ...
shenendoah
It might be a good idea to first lay down a barrier coat. Such as white bin or clear shellac. There are also numerous other products that would serve that purpose. These two are single component and readily available. Have you asked your material supplier? That might be your first step and they might have a product in their line that would be recommended for you to use.
9/5/18       #4: Urethane Moulding with Lacquer Fini ...
Bob Niemeyer  Member
Never had a problem yet with NC on urethane cast products. If unsure test with some Lacquer Thinner in a hidden spot. Just be sure there is not any mould release still on them as that will cause some adhesion problems.
9/5/18       #5: Urethane Moulding with Lacquer Fini ...
Jordan  Member
Thanks for the advice. Ekena will not comment on using lacquer and I havent talked with my Cambel rep. Will just have to try a bit first.
