Vapor proof LED lights
9/23/18
Tom gafgen
I was wondering if these lights would be suitable [ saftey wise ] for a homemade spray booth ? I would mount them behind glass to keep over spray off the lens .Any thoughts or suggestions would be appricated . Thanks
http://https://www.amazon.com/Garage-Ceiling-Fixture-Waterproof-Overhead/dp/B06VSZZ6W8?keywords=vapor+proof+led+lights&qid=1537709431&sr=8-30&ref=sr_1_30
9/23/18       #2: Vapor proof LED lights ...
mastercabman Member
Looks like they're be just fine
Remember if you have a good exhaust fan
You shouldn't worry to much about the vapor
9/23/18       #3: Vapor proof LED lights ...
herb johnson
these are not class one div two sealed and gasketed light, if you want to use them by code again my interpratation, mount them at least 3 feet back on the ceiliing of the booth, same goes for the side of the booth, also to meet a code again my interpratation, you will need a spray gun interlock so you cannot spray unless the exhaust fan is running
good luck
herb j
9/24/18       #4: Vapor proof LED lights ...
Tom gafgen
Thanks for the replies .
