Finishing bar top live edge with epoxy
9/25/18
Bruce
Need help in next step of finishing live edge bartop, have sanded to 320...there are a few small cracks nothing major...the question I have is should I fill the cracks (wood filler) or seal top with poly..sand again and then epoxy sealer coat then full flood
Any help...hints ...would be greatly appreciated
9/25/18       #2: Finishing bar top live edge with ep ...
Bart
You got this all wrong. First what brand epoxy are you going to use? I would recommend West 105 super clear epoxy. Second you use epoxy first and second AND then you can put a solvent or WB finish over it if you want. The epoxy will act as a stabilizer and super durable undercoat. I wouldn't recommend sanding to 320 either. You probably have burnished it somewhat and could have adhesion issues. Take it back to 150 and call it a day. Also use the epoxy for filler. This will all take some time.
my2cts good luck
9/25/18       #3: Finishing bar top live edge with ep ...
Bruce
Using Varathane Bar and Table Finish...from Home Depot
9/25/18       #4: Finishing bar top live edge with ep ...
System 3 epoxy has been selling a bar top epoxy for about 15 years. Mirror coat
It looks like they have a newer product called Mirror cast. Between the two of them you should have a winning combo. Their tech support is excellent.
scroll back and check out the Mirror Coat
Mirror cast
9/26/18       #5: Finishing bar top live edge with ep ...
Mirror cast would be a nightmare on the edges. It's going to run off and have runs and drips on the under side. I personally don't like natural edge slabs that look like they are encased in plastic. Just contradictory to the idea of a natural tree slab.
9/26/18       #6: Finishing bar top live edge with ep ...
Regardless if you like it or not epoxy is at the very least a good starting point.
I built and filled a wormy chestnut conference table with epoxy. Topcoated it with satin clear 2k poly.
It had enough really bad spots that I routed and let in 6-8 butterfly dutchmans.
If you contact the tech guys there is typically a non sanding recoat time with epoxy. West System says they get full chemical bonding when their resin is soft to your thumbnail. That way you can build coats faster than waiting overnight to sand and recoat. Definitely ask the company if it works with their product.
There are tricks to dealing with runs. You can sand a piece of 4" wide melamine smooth with 150 grit. Wax it with minwax paste or a car wax. Screw it to the bottom of the table to create a shelf. Now you can catch all of the run off and tool it away. We have to do things like this when doing fibreglass work. Or you just sand them off with 60 grit when its cured.
9/26/18       #7: Finishing bar top live edge with ep ...
That melamine shelf would be a task since the slab is natural edge.
9/27/18       #8: Finishing bar top live edge with ep ...
The edge is natural. I'm assuming the top and bot are more or less flat and parallel. The melamine is 4" wide. Fastened with regular screws every 16" or so to the bottom 2'' in from the edge. The resin flows off the top...down the edge...on to the melamine shelf. You let the resin cure until its green, then cut it off with a utility knife. Nothing hard here. It works well because the drip edge follows the perimeter. As you noted the resin can run under the edge and build up on the bottom.
