How to achieve this look?
9/26/18
Dan Cook
I am not quite sure how to achieve this look for a customer. It looks like someone ran the wood thru a rough planer with dull blades against the grain. Why anyone would want this finish I don't know, but we need to duplicate it. Any ideas?
9/26/18       #2: How to achieve this look? ...
The image is so dark, I can't tell at all. It just looks like they hit it with a hatchet from what I can see.
9/26/18       #3: How to achieve this look? ...
CraigM
It's a pretty standard distressed look. You can leave it roughsawn and distress it with a hammer, rasp, wire brush ect. to get the look you want. Stain it with the base brown, seal, use a black glaze, topcoat. It looks more like a heavy glaze than a breakaway glaze, I like the Mohawk one myself.
9/27/18       #4: How to achieve this look? ...
Dan cook
The thing that threw me is the marks seem to be more crossgrain than I usually see with distressing. I’ve done stain, glaze, distress before but not quite a pattern like this. It almost looks like tearout from a dull chipped planer knife with the material run backwards against the grain with chunks of material taken out. It is different than skip planing or just a rough pass through the planer.
9/27/18       #5: How to achieve this look? ...
Shane
skip planning or resaw with the bandsaw blade flipped backwards with big teeth....
9/27/18       #6: How to achieve this look? ...
Too consistent over the entire width of the board, narrow next to wide chips, and very uniform depth for planer chipping.
9/27/18       #7: How to achieve this look? ...
John Member
It looks like those marks were created with a bandsaw using a really rough cutting blade and then planed but not enough to remove all the cross grain scoring.
John
9/27/18       #8: How to achieve this look? ...
CWWOODWORKING
They take the material and run it through a machine that “rolls” the distressing on it. That’s why it looks so uniform. Don’t know how to replicate it.
Sold some furniture once where they took pine and rolled an oak grain on it and mixed species. Pretty cool way to hit a price point.
10/3/18       #9: How to achieve this look? ...
BH Davis  Member
It looks to me like skip faced lumber. Try taking a rough board and just skimming 1/64" to 1/32" off the face. That should leave unplaned areas similar to what you see in the photo.
10/3/18       #10: How to achieve this look? ...
CWWOODWORKING
I use skip planed quit a bit. Here is a dining table I just finished. Circular sawn though.
View higher quality, full size image (2388 X 2459)
10/3/18       #11: How to achieve this look? ...
CWWOODWORKING
Here is a top that is bandsawn.
View higher quality, full size image (2551 X 2596)
10/5/18       #12: How to achieve this look? ...
I've got some old doug fir beams. They were sawn a bandsaw. They look exactly like you orginal pics. In theory you could set up a decent size band saw with a wide kerf blade. Ideally use a powerfeed or carefully handfeed to maintain the consistent cuts per inch. Take a light pass on the planer and you should be ready to go.
