Dyes and NGR removal, best practice (how to) ?
11/19/18
Robert Member
Hi all !!
Hopping to get advice on how to remove dyes on birch ( or any wood for that matter!) with out using a bleaching agent ( chlorine or bleach)....or, sanding it down @_Q !
Searched the knowledge base, but not obvious to find !!
11/19/18       #2: Dyes and NGR removal, best practice ...
Robert Member
Try spraying 409 and scrub it while quite wet with a Maroon Scotch Brite Pad.
11/21/18       #3: Dyes and NGR removal, best practice ...
Robert
Thanks Rob, will have to make some shopping reserves next time I'm in US as....no where to find this Clorox 409 in Canada, hum !!
I'll have to be more creative !! @_#
11/23/18       #4: Dyes and NGR removal, best practice ...
Gary Peterson
did this once on cherry...dye blotched, either from poor precoat or something, I soaked top with water which diluted dye, then soaked up with paper towels...repeat, repeat, repeat. In the end, when water was lightly colored, I floated belt sander over the top until I was satisfied. Applied a new dye application which, fingers were crosed, worked fine.
