Spray booth fresh air
11/22/18
Jeff
I am looking at changing a few things and doing some reno’s on the shop. I was going to change the fresh air intake for the spray booth, and wanted to know what others are doing for filters? Some shops I know there is only filters on the make up air unit, but I have seen others that have a box with filters in it. I am curious if the extra filters make that much difference, and secondly how many filters should a guy use?
11/29/18       #2: Spray booth fresh air ...
herb johnson
typically on air makeup units they use metal mesh filters that can be cleaned with a power washer, some mfg use a poly material with an internal frame it varies, my suggestion is to use about 1.5x the amount of intake filters as exhaust as you want to slow down the air coming out of the fan, the more filter area the slower the velocity which is what you want
good luck
herb j
