need new cv
1/17/19
dar
I currently use gemini gem var, while its ok, we just dont get that slick lacquer feel with it
I know its hard to duplicate that precat feel and smoothness but has anyone used gemvar and switched to another cv and had better results, I am talking about pigmented cv the clears are much easier thanks
1/17/19       #2: need new cv ...
Shane
V84F90037 40 Gloss Sherwin CV... This was formally the Becker Acroma C.V.
has an incredibly smooth silky feel... much better than any precat I've ever sprayed. very forgiving... can be reduced heavily to achieve open pore finishes or straight up for that thick full fill plastic garbage that seems to be loved. If your a small user it's very economical because you can catalyze only what you need when you need it....The catalyst has a one year shelf life as well. keep it out of the light and cool.
1/17/19       #3: need new cv ...
Matt
Shane, I can't find any info on that V84F90037. Is there a name on the can like "Sherwood something something" that might help me find it?
Also, does it use the SW Kemvar catalyst like V66V21 or V66V26?
1/17/19       #4: need new cv ...
nick
I agree with Shane The SW F3 is a great product; trouble free application, sands well so self seal is good to go, silky smooth to the touch (customers love that), fairly priced (for years I paid $175.00 per five but as of 1/19 I now pay $200.00 per 5) and formaldehyde free (your customers will love that too!)
The down side; the clear is slightly amber so you can't clear coat pigmented jobs with it, I've had trouble getting the pigmented from time to time, and I don't believe it's as durable as the SW water-white. That said in the 1,200 or so gallons I've sprayed in the last 4- 5 years I've had two failures... one a dishwasher panel that was cut to fit on the job and left unsealed on the cut edge and a bar top in a home that's a after school hang-out for a pack of teenage boys...nuff said.
1/17/19       #5: need new cv ...
nick
PS; it uses the F3 catalysts, one for clear and a different one for the white.
The clear has a 24 hour pot life and the pigmented is 5 days!
1/17/19       #6: need new cv ...
Shane
The one I'm referring to is called
Kemvar 9320S and uses different catalyst and reducers based on slow,standard & fast drying... the regular catalyst is R07K10003..
I personally use the slow catalyst and reducers.... as well as adding 5% butyl cellosolve to slow it down even more... lays out beautiful... I have the luxury of force cure/gas fired oven to cure so I can slow it down to lay out beautiful and make sure it's fully cured.
1/17/19       #7: need new cv ...
Nick
Whoops, l apologize if l am confusing products. I assumed the F3 is the Becker-Acroma product that is now a SW product was the one you were referring to. Even if it's not the one, the SW F3 is still a great product and worth looking into.
1/17/19       #8: need new cv ...
Bob Niemeyer  Member
Becker Acroma formulations have a softer feel to them and also have better distension
than SW formulations. Get some samples and run some tests.
1/18/19       #9: need new cv ...
Shane
The SW formulations are one in the same..... Still coming out of Canada from Becker plant... just a different bucket. I know for a fact because I go through hundreds and hundreds of gallons a year of it and I'm in close conversations with Sherwin when batch times/production gets hung up on orders coming out of Canada. I've laid down a lot of different coatings and for a CV this is the best performing and feeling CV I've ever come across... I've tried them all.. from Akso,Milesi,Chemcraft,Mohawk,Sherwin/becker,ML Camp,Valspar & others that are smaller.... Valspar being the worst product I've personally had results with...Hands down this takes the cake IMO.
1/30/19       #10: need new cv ...
Matt
I'm going to second/third the praises for the clear Sherwin Williams F3 stuff. I've sprayed a few jobs with it. My normal clear is their Sherwood WW V84F83 (which is good in its own right).
But that F3 takes the cake. I can't use it on most jobs since it's not truly "water white" but on the jobs I have used it, it's been absolutely fantastic to spray. Hands down, the fastest curing, user-friendly, best looking CV I've sprayed.
9/17/19       #11: need new cv ...
jeff
I'm interested in trying the SW F3 conversion varnish, but I'm getting quoted a price of $150/gal, 5 gal min. A far cry from the $200/5 gal others have mentioned.
Currently using AXALTA (formerly Valspar) at about $65/gal for custom color matches. anybody else have any info on what they're currently paying for this product? I'd love to switch to a formaldehyde free CV product but $150 a gallon kind of a shocker. My door manufacturer sells me Becker Acroma for the same price and they double their cost on it. What up SW?
9/17/19       #12: need new cv ...
Nick
They are obviously quoting you the wrong price. If you haven't already, talk to your SW paint rep directly or if he's the one quoting that price try his boss...and show him this thread.
