Chemcraft Plastofix
3/28/19
Dean
Thinking of checking out chemcraft's CV. The Plastofix and Plasticolor. Anyone have any thoughts or advice?
3/28/19       #2: Chemcraft Plastofix ...
jim
Dean,
Just tried this for the first time. Primer, pigment with top coat. Been using ML Campbell claw lock 11 primer, stealth pigment with klevar. Have had good results with ml but the Plastofix first time out really gave a great build. The dry time for primer and top coat runs a little longer then the ml. 1 1/2 hours for primer before sand and the same for pigment. The solids is considerly higher and happy with the results. Going to run another job with the plastofix before I decide but it is looking good.
3/30/19       #3: Chemcraft Plastofix ...
Tom gafgen
Dean
I used plastofix for many years and was very happy with it . My distributor now only stocks chemlife 24 so I started using that,I must say the chem 24 is even better than the plastofix .I strongly reccomend you try the chem 24 in both clear and colored. The 24 hr pot life doesnt mean much for me but it gives cosistant predictable results with both AAA and HVLP gravity gun
